9V valves
Theleo De Bruyn 8 years ago • updated by Gustav Widén (System support) 8 years ago • 0
Dear reader,
I need for an aplication a proportional  9 Volt output. is this possible with the system running on 24 Volts? Because if i would use a COUT the voltage would be 24 V.
Is it maby possible to use a PWM output?
if so, how do i use PWM?
Another option is to run the system on 9V, is this stable to use?
