Differential Analog Sensor Signal
Doug Coutlee 4 years ago • updated 4 years ago • 2
I am looking for a way to use a shunt style current sensor that has a differential analog output with an IQAN module. Does anyone have suggestions? https://riedon.com/resistors/view/ssa  Riedon-Smart-Current-Sensor.pdf
The catalog for the device shows a circuit for converting to a "single ended output", that might be a solution for how to read this via a regular VIN on an IQAN module.
Thank you Gustav. We ended up using a setup with an ADC to convert and amplify the signal before sending it to an IQAN module input as a single ended signal.
https://www.digikey.com/en/blog/smart-current-sensors-for-isolated-high-current-applications
