Change VREF to 8V
Codie 3 years ago • updated 3 years ago • 2
Would it be possible to change VREF to 8V ?
The Vref supply is a stabilised 5VDC non-variable voltage built into the hardware and cannot be changed. it is intended to be used as a supply for 5VDC  sensors which is the standard in the automobile industry.
if you need an 8V supply you'll have to arrange it externally yourself.
