Simulate Input and Output Statuses
Chris Litwin 5 years ago in IQANsimulate updated by WareTech 3 months ago 8
Is there a way to set the statuses for inputs and outputs in IQAN Simulate 5? I know I can set COUT channels, but that option is greyed out on all other channels.
No public key without license!
We have a number of sales and service providers who want to simulate Iqan in order to guide and show customers.
But in the free IqanSimulate5, you can not create a public key unless you have a license!
Will this change, and when?
Chris Litwin, have you had any luck with setting input status in IQANsimulate? It's always been greyed out for me too, but it would be really helpful if we could change the status while simulating.
No we haven't found any way to do it.
Hello.
You can set the simulator to use the RAW value range for inputs.
You can the adjust those outside the min and max values you have set and in turn get the high and low errors.
It would be nice if there was a way to simulate errors on all the different types of output channels.
It exists for COUT, but adding this functionality for DOUT is in the backlog.
There is a feature request about simulating DOUT error here:
https://forum.iqan.se/communities/1/topics/1258-simulate-io-diagnostics-cases-for-hs-or-ls-digital-output-on-mc4x
Have there been any updates to this yet?
When I would like to set the status of an input that option is greyed out.
I am using IQAN Simulate version 7.01
Best Regards,
