IQAN-G11, IQANconnect & IQANsync ready for production
Johan Lidén (Product manager) 7 years ago in Gateways / G11/G12 updated 7 years ago 0
IQAN-G11 is now available to order. In combination with the IQANsync app and IQANconnect service this offers a very cost efficient remote diagnostic solution.
Image 570
Detailed IQAN-G11 information available at: http://ph.parker.com/us/17616/en/iqan-g11-bluetooth-adapter
IQANsync app available for both iOS and android. Links to apps from http://www.iqan.se/store/ click on IQANsync
IQANconnect connections can be purchased from http://www.iqan.se/store/ click on IQANconnect.
User manual for IQANsync / IQANconnect:
User Manual IQANsync and IQAN-G11 HY33-8416-UM_UK.pdf
Not reproducible
firmware g12
chuck streb 6 months ago in Gateways / G11/G12 updated by Gustav Widén (System support) 6 months ago 7
i am starting to use the g12's for the first time. they freeze in the middle of uploads.
do you have ability for updates and how do you do it.
we probably bought about 20 of these
Bluetooth connectivity with non parker apps
David Schulte 2 years ago in Gateways / G11/G12 updated by Gustav Widén (System support) 2 years ago 1
Is there a way to:
- customize the iqango app to show the customer logo (remove Parker)
- interact with a 3rd party app to adjust and measure
G11 on two non multi-master MD4s
Pawel Pekala 3 years ago in Gateways / G11/G12 updated by Gustav Widén (System support) 3 years ago 1
Is it possible to have one G11 module to handle two MD4s on non-multimaster applications if G11 is mapped on both diagnostic buses?
Installing 2 x G11 in one application
Paul Dillon 3 years ago in Gateways / G11/G12 updated by chuck streb 2 years ago 3
We install a G11 in the cab of all machines but on larger units one person cannot calibrate the joysticks at the second control station or monitor feedback from the controls because the  bluetooth drops out of range.  We thought we could add a second G11 at the other control station but on checking the application it returns an error of 'Too Many Modules of this Type'.  Will/could this be possible in future versions?
G11 Firmware issue
James A 5 years ago in Gateways / G11/G12 updated 4 years ago 14
I am having issues with the G11 v1.09 firmware.   Today I tried using my android phone (Pixel 3) I go to update a MD3 with a IQAN v4.07 program file.  Something I have done several times with out issue.  Right away the process files and the G11 blinks a 4,1 RED,Orange error code.  After some troubleshooting I narrowed it down to the G11 firmware.
Luckly I have a few G11 modems in stock as I sometime supply them to our customer with their machine.  The ones in stock came with firmware v1.07.  Some time ago IQANsync was updated and included v1.08.  Using either v1.07 or v1.08 I have had no issues with the G11 modem.  However if I update the G11 to v1.09 it will keep me from using it.
Any ideas on what is going on.  Is it possible to flash it back with v1.08 or v1.07 firmware?
G11 No Contact
Ethan Zeman 5 years ago in Gateways / G11/G12 updated by Edward Polzin 5 years ago 4
We are using a G11 modem connected to an MD4.  We are getting  NO CONTACT error with the unit.
However, when connecting to the unit with my phone using IQANsync it works fine and I can download logs from the MD4, etc even though it still shows NO CONTACT in the status.
Image 1784
Image 1783
Image 1782
Image 1781
Password protect projects
James A 6 years ago in Gateways / G11/G12 updated by Gustav Widén (System support) 6 years ago 2
When the G11 Bluetooth Modem was still in BETA one major limitation was that you could not flash a password protected project.
Has the limitation been resolved?
G11 Socket error 60
Greg Landon 7 years ago in Gateways / G11/G12 updated by Ulrik Zakariasson (Software development) 7 years ago 2
Using IQAN sync, we connect to the G11 through blue tooth and then receive a Socket Error#60. Any ideas? Looks like the phone is connected to the machine through blue tooth but is not establishing an internet connection (no green light). This was after asked us to update the firmware in the G11. Any ideas?
Bluetooth sensors?
Forrest 7 years ago in Gateways / G11/G12 0
Any plans for Bluetooth sensor reading via the G11?
