Not reproducible
firmware g12
chuck streb 6 months ago
in Gateways / G11/G12
updated by Gustav Widén (System support) 6 months ago •
7
i am starting to use the g12's for the first time. they freeze in the middle of uploads.
do you have ability for updates and how do you do it.
we probably bought about 20 of these
another note, we have used g11's up to this point with zero issues
We have also noticed stability issues with G12. Particularly when accessing using IQAN Run. In one application I actually changed back to a G11 as the passkey didn't seem to accept and the connection appeared more stable. There was a topic I raised about this recently.
I believe that other topic is this one Passkey not recognised? / Software / IQAN
Is there support on the board any longer?
If you need more direct support with troubleshooting your system, please reach out to your local Parker sales representative or distributor. They might not be able to answer right away, but could put you in contact with one of the regional application engineers.
In such off-forum discussions with a regular support contact, you might be able to disclose details about your system, for example how the bus layout looks and what software versions you are using.
IQANRUN 7.0 seems to have fixed the issue. I was running 6.08.23.6488
Not clear what the problem was, but seems solved.
