DM1 - Multiple SPN's
Nick Pridham 11 years ago in IQANdesign • updated by Gustav Widén (System support) 11 years ago • 3
MDL2
IQAN Design 3.19
SPN Conversion Method 3
Cummins T4F
I am having a problem with getting any more than 2 SPN's to pop up on the MDL2 screen. Looking at the project file I have 10 active SPN's.
The project file has 210 SPN's.
SPN conversion method 3 is called out by the engine spec. I have tried all the others and they don't seem to change the situation.
For the SPN channels that are active, but where you do not get a popup message, what is the dialog property set at? The default is "don't show", so that could be the reason.
That did the trick. Thank you. Nick
