+58
Native CANopen support
Peter Bo 12 years ago in IQANdesign • updated by Andrew Slaght 5 months ago • 16
Add dedicated CANopen channels to simplify implementation of CANopen communication. Also, support for EDS files would be nice.
+45
String functions
Gustav Widén (System support) 9 years ago in IQANdesign • updated by Jesus 12 months ago • 8
There are a few different forum questions and feature requests that I think would be possible to solve if we had added some string handling functions, for example comparison of text channel values:
http://forum.iqan.se/topics/1006-any-way-to-store-serial-number/
http://forum.iqan.se/topics/403-convert-machine-id-to-numbers/
,string concatenation:
http://forum.iqan.se/topics/162-idea-ability-to-change-tp-channel-value-using-qcode/
and conversion from integer to text
http://forum.iqan.se/topics/863-ascii-characters-from-j1939-parameter/
Anyone else who thinks this could be a good idea?
+32
Ethernet/modbus communications protocols on MD4?
David Holcomb 12 years ago in IQANdesign • updated by I CAN GO 2 years ago • 6
We frequently are integrating IQAN into larger systems that frequently have Ethernet/modbus in use.  Any hope of getting communication over the ethernet ports?
+27
touch number pad for adjusting parameters with MD4
andyr 12 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 26
using MD4 to adjust function parameters within adjust menu, could a pop-up touch number pad be made available as an option to enter a new value rather than scrolling which can take a long time if the adjust range set is wide with a small increment step number
+23
Free text comments in IQANdesign functionality view
It would be nice to have the possiblity to add a box for entering comments in the functionality view.
The Description field of the channels and objects work, but one must click on the individual channel to see it, or use the Project Documentation generation to see a more complete list of all descriptions.
+20
Sub-Groups in Adjust Groups
Barth Hollanddrain 11 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 9
Is it any way possible, or be made possible to create subgroups in the adjust-groups?
The applications we create use a lot of costumer-dependent values.
We use the MD4/5 screens on our machines, also to adjust values/parameters in the program.
Calibrating our systems takes a lot of time now, simply because of scrolling and searching for the right parameter.
Having sub-groups would speed things up.
Also having those subgroups optionaly password-protected would be a good addition.
+19
Any plan to support importing EDS file?
Frank GUO 8 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 4
Is there any plan to add importing EDS file into IQAN?
+18
Zoom tool in IQANdesign
It would be nice to be able to zoom in and out in the function group view and the system layout view.
+18
Lamp feature for lables
Fredrik Forsberg 12 years ago in IQANdesign • updated by Grisel, Evert-Jan 3 years ago • 8
It would be nice to have lables with lamp function. Be able to define "Input channel", "ON color" and "OFF color" for lables.It would be easier than making two lables as we do now.
+17
Custom re-usable Function Group
AxelC 12 years ago in IQANdesign • updated by Jean-Marc Zanni 5 years ago • 10 • 1 duplicate
In our company we use many times the same code in one application, and in differents target (MD3 and MD4)
for example we receive can bus data from two similar targets, then we do the same transformations for both on the data. Or we do the exact same task on a MD4 and a MD3.
That mean that we have 2 times the same code. We made a function group that we can copy but if we update one we have to update the other. And it is not that easy if the code is complicate.
It would be great to be able to make a kind on "User Function Group Lib", where we can define a function group with inputs and outputs that can be used in the application. Editing the function group in the lib would then update it every where.
Then the ability to export/import this lib to an other project would allow to be sure to have the same code on two different project.
I know that it is a big job but it would be such a great improvement.
