Touchscreen internal channel
LP C 9 years ago in IQANdesign • updated 9 years ago • 2
Is there an internal channel that goes on and off if someone touches the screen?
If so, can I use it?
I want to dim the screen when the system is standby for a long time and for that I know I can use the backlight control, but I also want to remove the dim if someone touches the screen to "wake" it up.
Is this possible?
Thank you
Unfortunately, there isn't any such thing available.
You should however try the built in screen saver functionality in the MD4, available in the menu system under 'Preferences' -> 'Display'.
Select 'Dimmed'
Do you think it will be available in the future?
