Mode selector for "Text Formatting Channel"
ksilovich 11 years ago in IQANdesign • updated 11 years ago • 2
It would be nice to be able to assign a State machine or parameter to a "Text Formatting Channel".
I have a situation where I have "Group A", 10 Text Parameters with with a state machine (10 states) assigned to it. And a "Group B" of 15 Text Parameters with a 15 state machine. I would like to use a Single Text formatting channel to Add Group A to B for certain situation.
Trying to display the text on the screen currently is painful.
Also on a separate note it would also be nice to be able to use a Text Formatting Channel in a Text Parameter.
Do all these text parameters need to be adjusted?
One trick if you have fixed texts that depend on states is to bring the state value into the TFC channel.
All the text would be user input-able, so I would need them to be adjustable.
I have used that trick in the past when I know what the text will be.
