Memory Utilization SIC on MD4
DavidH 9 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 9 years ago • 3
I have an application with an MD4-7 master. The system information channel that I have set up to report memory utilization has a hint attached to it stating there is a "Value/Module mismatch" and "The selected value is not available on that module type".
Is it true the MD4 can not report memory utilization on an SIC?
Satisfaction mark by DavidH 9 years ago
It's true!
Due to architectural differences and the fact that the MD4 has an order of a magnitude more memory than any other master module, it hasn't been a priority implementing that feature.
We might revisit the topic, should the need arise.
Thanks Marcus! This particular SIC channel was carried over from a program that had been on an MDL2. The MD4 has plenty of memory, there's no need to monitor that SIC anymore.
