Uploading error
Hasan Basri 9 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 9 years ago • 3
 I uploaded the program. At the end  of loading(finalizing) it did't reset. I waited 10 minutes and powered off the module. Since that time, I can't upload program on the module. What can I do?
Satisfaction mark by Hasan Basri 9 years ago
Try to start the module in safe mode (see instruction manual mc2)
Before you try to download your application, i advice to strip your application, because the estimated memory usage is far too big.
You can click the + buttons to find out which application parts use so much memory
