Simulation Screenshots
Lars Bolduc 9 years ago in IQANsimulate • updated by Ulrik Zakariasson (Software development) 9 years ago • 4
I think it would be convenient to be able to grab a printout of what is on the simulated screen in a PNG or JPEG format. For documentation purposes primarily.
Right now Windows' Snipping Tool works but it's a very slow process and you have to be very precise. It also is impossible to get each screenshot to be the same size as the display's (MD4 in my case) screen.
Thank you.
Answer
Answer
I believe F12 during the simulation will grab screen shots.
We use a program called SnagIt, that works really well for capturing the simulator screen. The capture area automatically adjusts to the window shape of the screen area, and then opens the capture in an editing window where you can resize, or add markups, save as to a different file type (png is the default).
https://www.techsmith.com/screen-capture.html
Answer
Thank you! This works perfectly.
