Error division by zero in system log
Laura 9 years ago in IQANdesign • updated 9 years ago • 3
What is the easiest way to program the software to prevent the error division by zero in the system log?
You can use Qcode and program:
If xxx = 0 then result:= yy else result:= formula
I hope this helps you
Thanks, this also works.
