Posibillity to visually occupy both OUT a and b, High Side Dout in List view
Fredrik Forsberg 9 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 2
On the IQAN MC4x modules it is possible to pair outputs to supply higher amperage.
In IQAN Design in the List view in the System layout, it is only the OUT_XXa that is visually occupied.
It would be nice if there were a option to visually occupy both OUT_XX a and b.
The problem is that i save the lists to pdf and use them to communicate the I/O information with our recourse's for making the electrical diagram. As it is now its easy to make a mistake when using paired outputs. OUT_XX b is not occupied in the list, meaning it wont make it in to the electrical diagram if one forgets that it should be a paired output.
/Fredrik
Just to be sure tha the idea is clear: When you connect e.g. DOUT-A in parallel with DOUT-B, you would want an option to mark DOUT-A in the list view to show that both pins are connected to something, one pin is going to the load and the other pin is connecting to DOUT-B ?
