Report filename depending of the machine ID
Laura 9 years ago in IQANscript • updated by Gustav Widén (System support) 9 years ago • 1
Is it possible to program the report filename in a script report so that the machine ID is placed in the report filename with a piece of text in the windows explorer.
Now all filenames of the different machines are the same.
They are placed in several folders with the machine ID, but it is not a unique name.
Kind regards,
Laura
Image 1100
No, the report filename is a fixed text, and as you write, the folder structure that gets created is the distinction between each run of the script.
I changed your question to an Idea topic instead.
