Material available
Aislan Scatolin 9 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 9 years ago • 1
Good morning, someone could make a material available for study purposes, Iqan beginner, and I would like to deepen my knowledge.
Thank you all for your attention.
Here's my rough instruction to new IQAN users here:
-Check out these videos: https://vimeo.com/channels/iqan
-Play around with the forklift/wheel loader examples. Try adding/moving stuff and see how it affects the program.
-Use the manual for reference.
Normally I'd also sit with them to explain the interface and give them a few assignments.
- Building input to output
- Adding math in between (e.g. vectors)
- Adding logic (IDCs)
Master math channels and IDCs first, then move to things like finite state machines.
Hope this helps.
