Import DBC in 5.02
chuck emmons 9 years ago in IQANdesign • updated by Anders Båth 8 years ago • 5
I can't switch some messages from "input" to "output".  It seems to have something to do with the size of the DB.  I can switch the ones at the beginning of the file but not the ones towards the end.
There seems to be a bug when clicking on the input/output and the list is scrolled to the second half. A workaround is to search for the CAN message to reduce the number of items in the list and then select input/output.
If I import signals from a dbc, then change the dbc, is there any way propogate those changes to the IQAN project without deleting and reimporting?
No, after adding the channels there is no connection to the dbc.
