Using multiple identical solutions with external functions
Greg R 9 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 8 years ago • 2
When dealing with a solution that includes an external function, if you use that solution more than once, the external reference is added to the project multiple times as well. This is inconvenient when updating external files because you need to update every reference.
When importing a project or solution in IQANdesign 5.03 the external function is reused if the file name matches.
