MD4 : Text Button : field Text can be parameter
Florent Mirieu de Labarre 9 years ago
in IQANdesign
updated by Ulrik Zakariasson (Software development) 9 years ago •
4
Hi
When you create a text button the field text is not parametrable. It could be great that we can change the value by setting or by a use of Text Parameter.
If you configure some stuff like 'auxilliary stuff', for each machine you can configure what we do the button.
Thank
Answer
Answer
Don't write anything in the Text property, add a Value element inside the button and connect that to a Text formatter.
Ulrik, after test is not the best solution because the text is white and when you press the button it stay white (AUX 1)
