rotating picture
Louis DUBARLE 12 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 9 years ago • 10
Hello
It is possible to rotate a picture with a mathematical function ?
best regard
Satisfaction mark by Louis DUBARLE 12 years ago
Yes you CAN in MD3-MD4
Exemple : https://www.dropbox.com/s/4myqyij2lkl5vaz/Rotationimage.ida3?dl=0
Choose an Interger math in Angle(°) :
Regards
Yes, you are right Florent, that is the way to do it on an MD3 (or MDL2), but unfortunately the MD4 lacks this feature. It will be added in IQANdesign 4. Meanwhile, it is possible to use the image selector property to do a workaround solution. See an example of this in the example file Rotating logo that is installed under My Documents\IQAN Files\Examples. A little bit more work, but possible to do :-)
Thank for you reply.
Jean-Baptiste
RGDH
Develloper for IQan system
Wow you can rotate the object but we cannot move it... Sad...
Added request for moving display page controls in runtime to our feature request list.
To whoever would like to respond, the drop box example is not available any longer. Can someone re-post it or explain the concept of rotating a picture. Also, did the move an image at runtime happen or still on the list of to do?
Thanks
On an MD3 you use the Rotate properties on the Image control to rotate it. On the MD4 there is no such property yet. It is planned for implementation later this year. Same thing with moving of images in runtime, later this year.
The example describing a workaround solution has been removed in IQANdesign 4, but here is a copy of it:
Rotating logo.ida4
Support for rotating images on the MD4 was introduced in IQANdesign 4.03.
