Communicating 2 different MC-31 through J1939
Diogo Tasquin Reducino 9 years ago in IQANdesign • updated by Gustav Widén (System support) 9 years ago • 2
Hey guys!
I'm trying to communicate two different MC-31 through J1939. They aren't in the same application, so I'm testing as they were connecting to outside J1939 modules (one mc31 is sending through JFOUT and the other has a JFIN waiting).
Through Generic CAN protocol I could make it work (I'm only testing an digital input into one lighting up a led onto the other module), but with J1939 I couldn't.
MC31 with the Digital Input
Image 1163
Image 1164
MC31 with the Digital Output
(generic outputs aren't connected because I was giving another try with J1939)
Image 1165
Image 1166
I'm pretty sure I misunderstood the PGN concept, but can't make any progress.
Satisfaction mark by Diogo Tasquin Reducino 9 years ago
Solved. Forgot to link the J1939 bus source address(in this case I left it 33, when it should be 39) with the first MC31 j1939 source address.
I don't think I can delete the post, so it's just an update.
Good to hear that you figured it out. Checking the bus traffic with IQANanalyze is usually a good way of spotting these things.
