IQANrun 4.00 released
Gustav Widén (System support) 11 years ago in IQANrun updated 11 years ago 3
Highlighted features
New connection type: IQANconnect
A new way to connect remotely via Internet where you pay per connection. The IQANconnect service is available for beta testing, more information will follow.
Image 253
Component navigator
The component navigator from IQANdesign is now available also in IQANrun. Use Ctrl-J for quick access.
Image 252
Compatibility
IQANrun 4.00 is fully compatible with version 3. It can be used for all operations such as adjust or accessing logs in version 3 system. IQAN Active Studio version 4 includes the IQANrun 2 setup file for use with older systems, and IQANrun 4 will give the option to automatically launch version 2 if connected to a system running that version.
I got a question about IQANrun 4 compatibility with the phase-out module IQAN-MDL2.
Even though the MDL2 is removed from IQANdesign, IQANrun 4 can still be used to diagnose 3.x systems with IQAN-MDL2.
how to buy iqan studio licence key for any version
The licenses for IQAN Creative Studio, IQAN Active Studio and IQAN Productive studio works with all current versions of the studios, from version 2 to version 4. The part numbers are found in the IQAN studios datasheet, and can be ordered from Parker sales companies or distributors
http://www.parker.com/literature/Electronic%20Controls%20Division/Literature%20files/IQAN-Studios_datasheet_HY33-8399-UK.pdf
