Adjusting Function Parameters within Display Page (MD4-7)
Diogo Tasquin Reducino 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 3
Is there a way to use the +/- feature (available through the Adjust option inside the Menu) in a display page created by me? I have a user friendly settings page, but it seems sloppy to use it with the Slider control.
Event Counters can also be used as Adjust Functions, which means that they can also be used with sliders. Couple of VDINs to an Event Counter should do what you need.
Thanks, I thought there was a simpler way to do it, but your solution works fine!
