IQANsimulate 5.03.11.5029 error: Measure terminated (no valid application in target module)
Paul Summers 8 years ago in IQANsimulate • updated by Jhonatan Rivera 3 years ago • 1
We have an application that was developed in IQANdesign 5.03.11.5029 but when we try to run the simulation we have the following error displayed and the MD4-10 is blank;
Image 1282
The system has approximately 8 arrays each sized for 2000 samples... if we reduce the sample side of each to < 950 samples, the simulation will run normally?!  Has anyone else experienced this?
Tenho um IQAN-MD4 COM UM ERRO NA TELA (NO APPLICATION)opid
Image 4004
