can identifier not within limits
Davey Lambelin 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 3
Fairly new to the Iqan design... When I try to receive a Can Message (generic 29bit identifier) with ID 0x18FF01, the ID is said to be out of range??? But my ID is in the ID range?!
Thanks for the help in advance
Regards
Davey
Image 1285
Image 1284
Have you set the bus to be 29 bit? it is set to 11 bit as default when adding it.
Thanks for the help! I was looking for this in the generic frame...
This solved the problem.
