Overload on MC43
Zach Dockter 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 3
I have an MC43 using a LS Digital Output on Parker solenoid (1A maybe) but the output shows overload.  I use a MC2 on the exact same solenoid and it works fine.  Anyone know why the MC43 is throwing the error but the MC2 is fine?
Satisfaction mark by Zach Dockter 8 years ago
Double check the output you are using with the max current rating in the instruction book.  Some of the Low Side outputs are low current (200 - 300 mA), i believe.
Interesting, the MC2 Low Side DO are rated for 2A each whereas the MC43 is limited to 300mA per output on the low side.  Bummer for me.
