IQAN Design 3.19 MDL2 Firmware Still Supports Serial Modem Communications ?
Nick Pridham 8 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 8 years ago • 3
IQAN Design 3.19 software
MDL2 Firmware
Does this combination still support the serial port functionality to interface with GSM modems ?
Satisfaction mark by Nick Pridham 8 years ago
This option used to be avail back in 2.63
In IQANdesign 3.x you need to add a G1 module (available under the legacy tab). There you will find connection related properties although they are named a bit different.
