MD4 - Problem in get project
linus torvaldus 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 1
I have MD4 display with CAN-A configured.
After writing software, I am able to flash the software on MD4 display. When I tried to get the project with same setup, it is giving me following error
"No reply from master module"
Same issue I checked for several times but same error. Allow to flash software but problem in get project.
Kindly advise.
What IQANdesign version are you using?
The symptom of being able to send but not get sounds as if the MD4 doesn't have an IdTag fitted, which prevents the application from running. But the error message would be different, it should look like this:
On a side note, may I pleas ask you to choose a different user name and enter your company in the user info?
