Qcode vs Object List Affect on Ram Usage
JamesV 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 2
I have a program that is at the limit of the available RAM in our master unit. I haven't made use of Qcode much but am wondering if I replace my object list logic with equivalent Qcode on a large scale will it result in lower RAM usage?
Thanks,
The effect is more likely the opposite. Channels that make use of object list tend to use slightly less RAM compared to Qcode, in particular when the object group method is utilized in a good way.
I'd say Qcode is more advantageous when there is a need to write slightly more complex logic, the advantage is mainly improved readability.
