Parameters-Feature Request-Set Min/Max/Step Size In Function Group
Nick Pridham 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 1
I would like to request the capability to set the min, max and step size from within the function group. Its much easier to set appropriate values when you are designing the function rather having to jump across into the adjust area.
Of course it should still be possible to change the min/max/step size from the adjust area.
Back to the way it looked in 2.x where the adjust limits were on the channels?
I can agree that that it was probably a quicker way to access the properties, but knowing the impact such a change would have on the software, I wouldn't vote for this as a favorite feature.
