Missing CAN traffic info on Iqan Design 5.03?
Kevin 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 3
When monitoring CAN traffic in 5.03 using the system overview part of the software, I am unable to see traffic and health status (green box) on some of the busses and modules. Sometimes clicking on one that is showing traffic OK makes the gauge and status disappear and have to click away from the system layout page to get it back again. Its almost as if the program will only show one of each type of bus from the display module only. Is this normal? Would be handy to be able to see gauges and status on all busses and modules in the system.
Using CAN USB device connecting laptop to diagnostic bus which is linked to all the modules in the system.
Image 1328
IQANdesign/IQANrun is connecting to one of the masters at the time, and the bus status you see is from the persepective of that master. By clicking on different masters, you see the status of different buses.
Great, worked just as explained, thanks.
