Show larger numbers in Qcode results
Kevin 8 years ago in IQANdesign • updated by Gustav Widén (System support) 7 years ago • 2
When monitoring Q Code live in IQAN Design 5.03, we are unable to 'see' the complete number generated by a line of code. See image below of the issue we are experiencing, there does not appear to be any way of increasing the 'live result' window size so we can see the whole result, rather than partial (you can see the numbers continuing off the page towards the left on both values in the image). This is particularly problematic when checking if you have the correct expected answers. Understandably its an issue when dealing with larger numbers and we have come unstuck sometimes because of minus signs missing and unable to tell its because its covered up. Is there a way of increasing the size of this box?
Image 1330
In the current version, there is no function for increasing the size of this box.
But I'll edit the topic to change it from  question to an idea.
With version 5, it is also a bit more noticeable compared to version 4, because of the slightly increased text size there is room for showing one less digit.
