How to get text over images in IQAN Design 2.63?
Doug Coutlee 11 years ago in IQANdesign • updated by Gustav Widén (System support) 11 years ago • 3
I am using IQAN Design 2.63 and I am trying to figure out how to get text to show up on top of images on the screen. No matter how I have the order set in the "Set Order" window, text always hides behind images.
Image 164
Satisfaction mark by Doug Coutlee 11 years ago
normally it works, if you put the image in a lower order number than your text:
Or a workaround with the base page function: Create one page with your pictures only as a background, create another page with the controls and use the first page as background.
Arno,
Thank you! Your suggestions were very helpful. I was able to get what I wanted by using the set control order. It was just a little bit finicky to get working. I may end up using the work around you suggested also.
Doug
