Update to version 3.17
MikaMan 8 years ago in IQANrun • updated by Thomas Moberg (System support) 3 years ago • 6
I have a problem. I'm trying to load project file to the unit but I get error message that "In order to upgrade the MD4-5 to version 4.00 and later the module must first be upgraded to at least version 3.17". How do I do that? I've tried with three different versions of the project file but I guess they all are version 4.00 or later. I've tried this with IQAN run 4.03, 4.07 and 5.xx and I get the same error message every time.
Hello Mika.
You need to download a version 3.x that is at least 3.17.
So if you download 3.19 that is available at our store site it should work.
https://www.iqan.se/store/downloads.html
Hi Thomas,
the problem now is that my project files are .Ida4 and I can't use those with version 3.19. Or can I? Or what should I do?
Hello Mika.
Just download any application with 3.19. Make a application in 3.19 with only an MD4-5 and download that.
The important part is not the application but the firmware that is downloaded.
After you have done that you can download your application with design4.
Hi Thomas,
I had no idea what I was doing but I managed to do it! Thank you for your help!
Hi Where can i get Iqan Design 3.X as its not on the store any Longer - I have an Old stock MD4-5 with the same issue
You can download it here.
https://www.iqan.se/downloads.html
At the bottom you can find older versions.
