+3
DM1 Lamp Status -flash
DavidH 8 years ago in IQANdesign • updated by Gustav Widén (System support) 7 years ago • 5
I'm trying to find a way to show the J1939 DM1 lamp status. The MDGN channel will show the lamps on or off, but there are varying levels of flashing indicated by 65226 that I can't seem to access.
Are there any plans to include the flashing levels in the MDGN channel?
Image 1376
Thanks!
I would like to say "Good, but not satisfied", since you did address this issue, but it doesn't solve the problem we have. Will this feature be added to a version of IQANdesign that does support the XA2? All of our current products use XA2 modules, which are not supported by IQANdesign 6.00.
Satisfaction mark by DavidH 7 years ago
That is correct, the MDGN:s will only show Protect/Amber Warning/Red stop/Malfunction indicator Lamp
I know we have had a few requests for making the MDGN channels for lamp status blink with the flash for the corresponding lamp in the past. I can change the forum post from a question to a feature request idea.
Added as property on DM1IN channel, default value when upgrading an application is False, change this to True make the MDGN:s blink according to the DM1 flash.
Available in 6.00
https://forum.iqan.se/communities/1/topics/2046-iqandesign-6-is-now-available
Thanks for the feedback David
I believe this one should be possible to add in IQANdesign 5.x also, I know it is  an important function for displaying the engine diagnostic information.
