Externals draop down drops below windows task bar
Greg R 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 4
Kind of a funny issue. We have a large external function library that causes the external function drop down list to drop below the Windows task bar. This makes the last option unreachable unless i move the taskbar.
Is it one external file with many function groups that does this? Or a high number of external function files?
You could get some more space by minimizing the lists of function group that you get from each external function file.
We actually only use ony function per external file.
Thanks for sharing the printscreen, here it becomes quite clear that the list view could use some improvement..
