Ethernet communications with MC42
Chan White 8 years ago in IQANdesign updated by C. Drouaud 8 years ago 1
I'm working on my first project using a MC42, our master already has an application loaded.
I'm using design 5, when trying to communicate via Ethernet, my LAN identifies the connection as unidentified.
When I use Get project, no modules are discovered.
Can any one help me with this issue?
I had the same issues. It sometimes takes time to identify the Ethernet connection. Be patient and see if it's finally detected.
