GFIN - add Enable parameter
Florent Mirieu de Labarre 8 years ago in IQANdesign updated 8 years ago 2
Dear could you add a enable parameter on all CanBus function. If we have some option material, it is easy to desactivate some CanBus function.
In generale it could nice to add Enable Parameter on all function.
Regards
My recommendation for functions that are optional is to use the Enable property on the function group the channels are located in. Have you tried this method?
If the entire CAN bus node, you can use the enable on the module to avoid getting the No contact error.
I know this feature, but it is not simple to use.
