Limit the number of run of a script
C. Drouaud 8 years ago in IQANscript • updated by Gustav Widén (System support) 8 years ago • 2
I want to limit the number of times a script can be run on a machine. I want it to be run only once.
I created a digital parameter in my project, set as false as default and when I run the script, it changes the value of the parameter to true. This parameter can only be changed through this script or by authorized technician.
In my script, I want to check if the digital parameter is true or false. If it is false, it can run the fulll script and if it is true, the script does nothing.
I didn't achieve to check this. I tried to use If(Parameter) but it doesn't work.
Is it the correct way to do it ? Should it work with the If or can I use something else ?
Thanks in advance,
Hello and happy new year,
Anyone to help me please ?
Thanks in advance.
The idea you had for setting a Digital Parameter in the application after completing the script on a particular machine should have worked, not sure why it didn't.
Perhaps there was a problem with where you placed the measure action to measure the Digital Parameter.
Try something like this:
See attached example:
Script runs once per machine.issx
