Limit Event counter Channel (ECNT)
Giel Coopman 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 2
Is it possible to limit an Event counter channel with a maximum and a minimum value?
Answer
Answer
Hi Giel, the event counter channel is typically limited in the "Increasing" and "Decreasing" columns when using the Object list method.  Similar limits can be used in the Qcode method.
As an example:
In the increasing column:
A: Button 1 Press  (Single object)
B: ECNT<10
C: A and B
This would limit the event counter channel from increasing above a value of 10
Answer
As an example:
B: ECNT<10
C: A and B
