Option to send only certain parameters to system?
Kevin 8 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 2
We would like to see the ability to have more options on the send dialogue box where it asks what parameters etc to send or reset. Sometimes we have multiple machines running software where we are tweaking small parts of a program prior to delivery by changing parameters and default values. Once we have a final piece of software we then insert it into the remaining machines but cannot reset default values because it will change all the other parameters in the software instead of what we have been tweaking. Can we have a way of selecting certain parameters to overwrite?
Hi Kevin, This may help:
If the sets of parameters that you do not want to overwrite are always the same then you could test with different login profiles.  In other words you could group the parameters you do not want to overwrite into Security group with order "0". If you login with Security order 1 and send the settings, then the settings in Security order profile "0" will not be overwritten.
What about using a small script in IQANscript ? Then you can perform a number of Set parameter actions.
