adjustable parameters in disabled function blocks
Greg R 8 years ago in IQANrun • updated by Gustav Widén (System support) 8 years ago • 2
When a function block is disabled, the adjustable parameters in that block are not able to be changed (including on screen as well as through IQAN Run). This is inconvenient because in order to change the values, the system must be put in a state in which the function block is enabled. Is it possible to make it so the adjustable parameters are changable while the function block is disabled?
Hello Greg.
Not in the way i think you want.
But you could have just the adjustable parameter located outside of the function group.
That way they will be adjustable when the group is disabled.
Then you bring them in to the group either via a 'Function group input' channel or having them set as Public.
