Generic parameter in channel (GPIN) Value in simulation
AxelC 11 years ago in IQANdesign • updated by Richard 3 years ago • 4
It would be great to be able to enter the GPIN value with keyboard on simulation.
Actually depending on the size of the GPIN the possible values (from the cursor) doesn't allow to test every values.
For exemple, my speed value jump from 311 to 638.
Satisfaction mark by AxelC 11 years ago
Hello Axel
What you do is add your GPIN channel to a simulation group in the simulator.
From there you can adjust your value by typing in what you want to have.
THanks for the explanation, I didn't know about this functionality, it will save me lot of time!
I get all the parameter in channels as gray that you can attempt to alter the values of but snap back to 0 so there is no effect. the group the parameters are in is not disabled,
This is happening in a multi-master system with inputs into an MD4-7 from a separate master unit when trying to simulate the inputs into the MD4 screen. not sure what is happening.
