can variable updating
Zach 11 years ago in IQANdesign • updated by Gustav Widén (System support) 11 years ago • 1
Has anyone else had an issue with spn warnings getting stuck on?
They update when I pass another spn message on the can, but some don't seem to turn off until instructed of another change.
Is there a way to trigger my spns to be checked and updated?
What device is it that is sending out the DM1?
The IQAN DM1 channel will be updated when the next DM1 comes in. If the staus of the device that was sending the DM1 has changed, then it should be sending a new DM1, and that should clear the value on the SPN channel that was indicating a FMI.
