Output fréquency
Louis DUBARLE 11 years ago
in IQANdesign
updated by Gustav Widén (System support) 11 years ago •
2
Do you have a solution for create a frequency 3000Hz with a Parker calculateur ?
Thank
needs a very smooth ripple?
On the IQAN-XT2, the COUT:s work very differently compared to the other modern modules, the current is controlled with a high frequency PWM (don't remember the exact frequency), and the dither is added as a sinusoidal signal on top of that. The dither on an XT2 can be set to 25-150 Hz, but if you set the amplitude all the way down to zero, eliminating the dither.
