Display refresh issue using moving images
Olivier Cote 7 years ago in IQANsimulate updated 7 years ago 1
Hi, I got some problem on image refreshing while moving. Actually we are using the image selector at the same time than the moving position.Please look at the rolling menu display in this video.
Display_refresh_issue_with_Moving_images.mp4
We will try to "Hide" and "Show" these moving pictures during the transition because it seams the only way we can "refresh" the display and hide bugs, but if you have a more elegant solution please advise !
Image 1615
Finally the problem wasn't regarding the moving images, it was due to the image selector. Our "superposed" images wasn't exactly all the same sizes. The problem seams to be solved now we resized exactly the same each image used on each single image selector.
