IQANrun 3.14.8 released
Ulrik Zakariasson (Software development) 12 years ago in IQANrun • updated 11 years ago • 2
Bug fixes
Large logs (>65536 rows) is not handled with xlsx-format
Fixed.
Get settings script action only works once
When getting settings multiple times using script the settings was appended each time causing the saved settings file to grow. Sending such a file would still result in the correct settings.
Problem solved.
We want to connect to the MD4 display via a WIFI router. To get it working we need the IP address from the MD4. Where can i find that or how can we modify this
Please see this topic on 3.18 which has support for static IP address. It's in section 19820 Ethernet direct connection.
