Incrementing a math channel
J C. Crow 7 years ago in IQANdesign • updated 7 years ago • 1
How do I increment a value  by a fixed amount when a condition is true? I do not want it to increment again until the condition is false then turns true again.
I am trying to set a requested engine speed using a MACI channel. When I bump the throttle switch for less than 350 ms, I want to increase the channel by a 25 RPM increment. It seems that the simulation is adding 25 RPM to the channel on every cycle. I am getting several increments of 25 on each bump instead of 1 25 increment increase.
If I hold the throttle input for more than 350 ms, I want to add 50 RPM every 250 ms to control to the throttle rate. I was trying to using a timer channel to increment the value by a fixed amount every 250 ms, but it seems this is happening faster than it should also.
I resolved my issue by adding a positive flank to the equation. I had not used flanks before.
