Can Not open two application the same time
Andy Pauly 7 years ago updated 7 years ago 4
Hello
I have to work with IQANdesign5.04 and IQANdesign6. Both software are installed on my computer. Before I could open two application the same time by open IQANdesign and open a second application by just double clicking on windows explorer.
Function groups, channels etc. could be easly moved by cut and past from one application to the other.
Now I cannot open two IQANdesign5.04 applications. Always the second IQAN design opens in IQANdesign6.0. Even I set up in windows "open with to IQANdesign5.04" to open the software with the old version. I can only open IQANdesign6.0 over the explorer now. How can I open two IQANdesign 5.04?
Regards
Andy Pauly
To launch another instance of a specific IQANdesign version, the easiest is to type IQANdesign in the windows start menu and select the one you want.
For some discussion on working with 5 and 6 in parallel, also see this post:
https://forum.iqan.se/communities/1/topics/2054-iqan-design-5-applications-opens-with-iqan-design-6-beta-application
Hello
I am working with IQANsimulate. I wanted to use your Marco-Excel "IQANsimulate control" because my automated test is very complex. You marko works only with IQANsimulate6.00 in your software "IQANsimulate control". How can I change the marco to use IQANsimulate 5.04.?
Regards
Andy
